for the past few days our dvd has been losing all channels when switched off. The latest comments to a seemingly similar problem are from 2013 so I was wondering whether anyone knows of the current cause and, hopefully, also a solution to this.
Any tips will be welcome but I have tried the factory reset several times already with - you guessed it - absolutely no effect.
Many thanks
It's very strange: you have the latest firmware and you did the unplugging trick to free up the memory but still no joy... if you don't loose all the other setting it cannot even be a problem of the battery. I guess you two live in the same are and get the broadcast from the same repeater...
So, the sorry saga continues
the machine started loosing channels in July
spoke to the forum - you mentioned firmware update
spoke to Sony
they finallly sent me a disc which doesn't work - I know this because it's not doing what that the printed blurb from Internet that Sony sent me says it should be doing
Just come off phone with Sony
The can either send me another disc or advise me to go an authorised engineer.
I have no faith in the new disc as the first one that they burnt and sent doesn't work
anyone have any dealing with taking the machine to a man to get it fixed
£39 just to look at it
Sony have recommended Gwynne TV services in Braintree - anyone used them?
Do I a) take machine to man and hope he can fix it as Sony man says it is repairable
b) bin it and buy a replacement - but not Sony as they don't make it anymore
c) go straight to the daily mail as I'm fed up of Sony not taking responsibility for their update breaking my machine ?
Sorry for for sounding ranty but I am very annoyed !
My email to Sony
Ref no 12940792
Sir
I have had this machine for a number of years and other than the infamous channel drop of 2013 it has worked fine - as I expect my Sony products to ( we have a number)
For some reason Sony issued an update in ? June time which caused my and many other machines to drop channels on a whim, and then on an increasingly regular basis
I have posted on your forum looking for answers and the issue appears to be a firmware problem.
I have no idea what this means
I rang Sony who confirmed it was firmware issue caused by one of their updates but this can be fixed by going on line and burning a cd in a certain way including bowing to the moon three times on Sunday whilst holding a 4 leaf clover in one hand and a rabbits foot in the other.
I don't have the option to burn discs as I have an iPad.
The kind man offered to send me a disc which finally arrived 2 weeks later along with instructions printed from the Internet
I've followed these instructions and they do not work
The disc does NOTHING at all
Husband has followed instructions - same result
I rang Sony again today and spoke to Ahmed - a very nice man who was very patient with my crossness at the situation ( not him)
He suggested I have another disc sent out - why ? What guarantee do I have that the second one will work when the first one allegedly came from the 'I can fix it' dept postmarked Brigend?
In the mean time the machine has got even worse and regardless of how often I tune it -- which has been daily for 6 weeks, it now drops EVERYTHING the second it gets turned off. I can record if I am in the room to press the rec button on the remote. What exactly is the use of that? I may as well be watching the programme
Your man has suggested I drive the machine to Braintree to an authorised engineer who may be able to repair the machine - if it is repairable as Ahmed seems to think
That's a round trip of 90 miles to drop it off and another 90 to pick it up and an instant £39 to look at it
At HMRC rates that's the thick end of £100 in travel plus £39 before the engineer decides how ever many parts are needed.
Does that seem fair that I have to go all this expense in terms of time, money and aggravation to fix something you broke ?
I'm tempted to replace the machine and send you the bill but you don't make it anymore so you are at grave risk of loosing a hitherto very loyal Sony customer.
I'd really like to hear from you about why you issued the upgrade that broke the machine to start with and why this sorry saga has occurred
I'd also like to know what gesture of goodwill you are prepared to make in order for me to repair or replace the machine.
Yours
Sent from my iPad
Please excuse any typos. Auto correct and I don't always agree.
Heskete, just some few check:
Just for the sake of truth the reason for the fault is not a firmware upgrade (that I assume you never did and it's not done automatically by the device): simply the firmware developed at the time was not expected to manage the number of digital channel that are available nowadays. Th fix was developed firstly in Italy in 2010 when the digital switch off happened (before England, incredibly) and then distributed also in GB when the same problem appeared...
I've given up and have bought a Panasonic
that's another customer Sony has lost
this sorry saga has been going on since May and I've lost patience
thank you you community people for trying to help but I don't think it's fixable and Im refusing to spend any more time or money on this especially when no one at Sony wants to take me seriously
Rooobb
I followed the instructions to the letter - as did hubby and I talked the process through as I was in the phone with Sony
the the machine does play other discs
the one I was sent did not work .
I am am capable of reading instructions
