DAV-TZ230 problems
profile.country.en_GB.title
chappers75
DAV-TZ230 problems
Can anyone tell me how to get the TV sound to come out via my DAV system?Please.. I have the manual in English and have attached cables as directed but still notihing coming out when in tv mode. Works fine with USB & DVD. The manual indicates the scart cable will take audio in. Is this correct and if so does this mean I need a specifc scart?My TV has ability to send info out but it doesnt seem to get through.
3 REPLIES 3
Blencogo
profile.country.da_DK.title
Kenneth76
Have the same system, I've connected it like the above pictures, tv--->system with both scart and hdmi, then set the cinema system to tv and it should work :slight_smile:
Herentals1
Please can you help i have connted it to the T.V, also have sky HD and can only get sound from the speaker on the DVD
