ct 790 please wait on display for 10 minutes
steve808
Hi Guys
could anyone help me please, i have a ct790 sound bar connected to a sony bravia 43xe7073 with HDMI cable connected to the ARC sockets
lately when system switched on please wait will keep scrolling across sound bar display & no sound through sound bar
i have unplugged tv & sound bar power cords & HDMI Lead , contacts in leads are good
i cannot get to setup screen to update software
any help would be appreciated
Regards  Steve
4 REPLIES 4
Pascale_F
Moderator
Hi Steve,
Welcome to the community.
I'll look into this for you and see if I can find out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
Win_88
Specialist
Hi Steve808,
I took a look at the Manual and since you will need to access the menus either to update or reset the unit, there's nothing to do apart from consulting with you nearest service centre which can be located using this link:
https://locator.sony/en_GB/servicecenters
Win_88
steve808
Hi Win-88
Thanks for the advice i went to local sony service center , they carried out a reset and carried out software update
the soundbar now works correctly
once again many thanks
                                         Steve808
Mick_D
Moderator
Thanks for the uodate Steve, great to hear you got it sorted!
Mick
