Connections from HDD to KD-65XF9005 to STR-DA1200ES to 7.1 surround
skymanuk
Hello I’m wanting to ask if anyone has any suggestions for the best possible way to connect my STR-DA1200ES to my KD-65XF9005
I’ve got the hdmi from the amp for my stand alone recorder but I’m wanting to watch some free sound samples via a usb hard drive plugged into the TV
It looks like ark isn’t an option and I’m sure I’m only getting 5.1 rather than 7.1 via the optical and coaxial outs from the tv to the amp
any advice would be greatly received, I love my old amp so please don’t suggest getting rid of it as it suits my room it’s powerful enough for all my separate speakers and sub and sounds great but it would be great to get a 7.1 signal to the amp from the hdd via the TV
cheers Dean
rooobb
Unfortunately HDMI ARC didn't exist at the time and optical could send only 5.1 max....
2 REPLIES 2
rooobb
skymanuk
Thanks for the feedback, so you recon it’s time to get the amp upgraded... poor old thing has done me proud for years, do you suggest any of the Sony amps with arc will do the job. Cheers Dean
