4 ohm speakers - 1040 receiver
mpezzer
Hi all I'm thinking of upgrading my speakers, would 4 ohm speakers put to much stress on the 1040's amplifier ?
Anonymous
Hi there
I would not advise you to add 4ohm speakers to this AMP.  Especially if you intend use the AV Receiver at higher volumes and/or longer periods of time.  There are many 6/8ohm speakers on the market that would do the job nicely.  I can only guess that the 4ohm speakers are from a different piece of equipment?
3 REPLIES 3
Anonymous
Hi there
mpezzer
Thank you for your fast reply. I've got a 5.1 sub sat system by M&K which is no longer available to buy , I'd like to upgrade to 7.1 using similar M&K speakers .
Anonymous
No problems :slight_smile:
You will probably over heat the AV Receiver (prolonged use/driven hard) and shorten the life span doing it that way.
Good luck with everything :four_leaf_clover:
