24fps or 60fps? That is the question.
Blumine1818
A video plays back on my laptop at 24fps. I use VLC media player.
The same video, whether USB or bluray disc plays back at 60fps.
Is this the norm or am I missing a setting?
My kit:
Sony 55" XF9005
Sony Soundbar HT-ZF9
Sony 4k player UBP-X800
3 REPLIES 3
IamNic
Hello @Blumine1818,
would you please elaborate whether I understand it correcly - the file is a 24fps file, which you can confirm in the properties of said file on your computer?
Do you play it from USB on the Blu-Ray player or on the TV? If it is played back at 60fps, that can mean two things - the playback device interpolates images - the TV receives a 60fps signal but the file is still being played back at the original framerate with repeating images.
- Nic
Blumine1818
Hi Nic
That is correct.
Thus far I have just played via USB to the bluray player.
This also happens with 24 FPS video files I burn to bluray and playback through the player.
I notice a slight degradation in playback quality at 60fps.
HannahEd01
