We have the above system, just obtained second hand from a friend & the mini disc player, which otherwise works fine, isn't ejecting the minidisc, which is now stuck in the machine. Can anyone suggest a solution to a) retrieving the disc b) fixing the eject system on the minidisc unit & c) stopping the same problem from happening again?
Thanks
