My Xperia SP can't connect to Sony Select.
profile.country.GR.title
lukasito2011
It only says, "No network connection. Please try again later."
10 REPLIES 10
Piscie
Hey @lukasito2011 ,
Have you restarted your phone and tried different internet source?
lukasito2011
Nope
EMS_MO72
Did you make sure of your internet connection?
lukasito2011
Yeah, it is connected to the internet but it could not connect the server.
EMS_MO72
I don't know if this going to work, but try the steps in this link on the app if possible and check if it will work: https://www.sony.co.uk/electronics/support/mobile-phones-tablets-mobile-phones/xperia-sp/articles/00...
lukasito2011
I did these steps and it did not work.
EMS_MO72
Did you try to perform factory data reset?
lukasito2011
When I try a factory reset, the phone's touchscreen not stop responding.
EMS_MO72
That's bad.
The thing is that the device is very old and it definitely reached end of support. So, what's happening with the phone is expected unfortunately. I don't believe that there's any troubleshooting steps that we can try further in this case.
