Experia E no notification of text messages
GELÖST
certa
Besucher
i have just bought a new Experia E, the text facility worked for 6 hours and failed totally. there is no notification of a recieved message, no tone, no vibration, no incoming log update. BUT the messages have arrived    HELP......all settings have been checked
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
certa
Besucher
i was ahead of you there. i have refreshed unit s/w i'm now in the process of testing
9 ANTWORTEN 9
profile.country.RO.title
_alexdon_
Take a look in messages settings and check notification vibration and notification.Also,in settings-sounds,make sure you have a default notification and your phone is on normal mode(not vibration nor silent).
alexdon
Thommo
Open messages app then open the options then select settings - Check that Notify or new messages in the staus bar is ticked
certa
Besucher
tryed all that (again)  still does not work, rx message no notification
certa
Besucher
done all that again still no notifications
certa
Besucher
still no joy...have been at this for 4 hjours yesterday and 2 today
_alexdon_
Stop spamming and creating other topics.You have the edit button.
Download sony update service and repair your device:
http://www.sonymobile.com/gb/tools/update-service/
alexdon
certa
Besucher
certa
Besucher
it works fine now but for how long??
_alexdon_
As I have told you before,use the edit reply button and do not spam.Please take it into account.You have to wait and see for how long.
alexdon
