Hi i have some strange problem on my Sony Experia E1 phone.
I have done 'factory reset' , and now some app with name: ''Manage Settings'' trying to install itself on my Sony Experia E1.
This happen when i turn ''off'' an ''on'' screen. I receive message to install this app, which is from ''unknown source''.
I always refuse this, but app insist to be installed again and again..
In security menu i was disable ''unknown sources''.
What should i do?
Or is this app some system app or something?
I have kit kat 4.4
All programs i was downloaded is from ''play store''.
I can't find that this program is related to any app i already have on phone.
Yes i was install:
viber
digital clock widget xperia
zedge
ccleaner
avast
opera mini
uc browser
adobe reader
flash player(official)
advanced task manager
perfect uninstaller
rar
nova launcher
simple rss widget
picsart
aimp
audio recorder(sony)
floating stickies
text edit
All apps are from playstore, only flash player is from: http://helpx.adobe.com/flash-player/kb/archived-flash-player-versions.html
Rickard thank you for your help, i found problem.
App with name ''com.game.arrangeblock-1.apk'' was problem.
I forget that i was inastall this game after reset my phone.
This game doesn't exist anymore on playstore , probably because of virus.
After i remove this app, problem is gone..
Thank you for all your help..
Glad to hear that you found the app and thanks for the feedback
Alright, looking at this so called "application" it is actually a virus designed for the Android KitKat. The virus is a ransomware phone locker. If you download Malwarebytes Mobile from the Google Play store, give it a run and it should find it. I can give you direct instructions on how to do it. If you need any more help, please do not hesitate to contact me or add me as a community friend, I am here to help with your phone questions as wel as the helpful staff of the Sony Forums.
Thanks for visiting!
