Sony DSC-950 Flash wont work ?
profile.country.en_GB.title
romclel37
Sony cybershot camera flash wont work , tried all differant settings but no luck . going on hols soon   so need it fixed quick  help ?
blaireau_photo
Hello romclel37 - welcome to the Sony Forums :slight_smile:
If you have definitely tried every possible flash setting and it still won't function correctly, it may need to be assessed for a repair. If you have had the camera for less than 12 months it may be covered by the warranty and so it would probably be best to contact the Customer Services team at Sony. If it is more than a year old they will be able to advise you about possible repair costs.
There is a useful forum thread relating to getting in touch with Sony and it is located here:
http://www.sony.co.uk/discussions/message/651957#651957
Thanks,
Simon
1 REPLY 1
blaireau_photo
Thanks,
Simon
