The viewfinder switches off when the sun is behind me is there something in the menu to correct this ?
@Craigar12 does that happen with any source of strong light as well or just the sunlight?
Sorry for the delay replying ,yes any strong light has the same effect and the viewfinder switches off ….dont recall when I was looking to buy the camera any of the so called reviewers mentioning this fault ! For me it would have been a deal breaker and I would have bought elsewhere
@Craigar12 Try removing the battery pack, wait for about a minute or something and then re-insert the battery pack, then turn on the power, because it might be a glitch or something. If it didn't work, you can initialize the camera: https://helpguide.sony.net/dsc/1810/v1/en/contents/TP0001117097.html?search=reset
