I have a DSC-S2000 and when i switch it on the lcd screen does not display anything although the zoom and flash works. I need a solution?
Hello masadler
If removing the battery and replacing it after 10-15 minutes doesn't rectify the problem, it is likely that there is an internal fault within the camera and I would advise getting in touch with Sony Customer Services to see if a repair would be economically viable - contact details are in this thread:
http://www.sony.co.uk/discussions/message/651957#651957
You may get a better quote from an independent local service centre so I would advise making some enquiries.
Thanks,
Simon
Hello masadler
Thanks,
Simon
