Hx200V Battery stuck in Camera release button will not release it
profile.country.en_GB.title
tapler
Hi
Sony HX200V
Please can you help
Absolutely love the camera, I have Sony A900 and A850 with all the lenses which are also superb!!!.
When I want to go light or on Holiday I take the HX200V it does all that the above does  . . .and fits in my pocket!!!
My first problem . . . as I take lots of Photos I bought a compatible battery and fitted it but the release catch will not release the battery  . . . it still charges and works ok but now I cannot use two charged up batteries.
Any suggestions please?
Many thanks
4 REPLIES 4
Mick2011
Hi :slight_smile:
I'm not sure what the problem is here :thinking:
Perhaps using a genuine Sony battery would be the solution?
Mick
tapler
Hi Mick
Absolutely yes Michael . . . I know what I should have done . . .and I am very sorry and will not do it again promise!!! :dizzy:  . . . .but please do you know of any workaround to get that nasty little battery out? as I now have a brilliant camera and a very lonely:smileysad: genuine sony battery just wanting to be used.
many thanks
Mick2011
Sorry, I have no idea! It could be anything preventing the release from working. Being a non-standard battery, I have no reference for the problem.
All I can suggest is taking it to a repair centre and asking them to have a look at it :thinking:
Mick
tapler
Thanks for trying to help Mick!!
many thanks
