How can I convert my Sony clips to work on "iMovie"?
profile.country.en_GB.title
andpix
I'm having trouble getting clips from my Sony Camera/Camcorder to work  on iMovie. The file type of the clips are "MPG" and before the number of  each clip it says "M2U". Can anyone help me out?
http://www.uklv.info/g.gif
1 REPLY 1
blaireau_photo
Hello andpix :slight_smile:
Which model of camcorder are you using? If you let me know I can have a look to see if there is any camera specific guidance for importing to iMovie.
Thanks,
Simon
