DSC-HX9V will not turn off or react in any way- what to do??
profile.country.fi_FI.title
jippinen
Please help, my camera suddenly completely froze/jammed:
It does not do anything, i.e. switch off or react in any way.
A picture is frozen on screen and zoom is half out.
Please help, how do I even get the power go off???
Anybody have had the same problem?
Thanks!
1 REPLY 1
profile.country.en_GB.title
blaireau_photo
Hello,
To get the power to go off, you can remove the battery from the camera and then re-insert it to see if this resets the camera to a usable state. Bear in mind that doing this whilst the camera is writing data to the memory card could damage the card itself but if it has indeed totally frozen for a long period of time then the chances of this happening are very small.
Hope this helps,
Simon
