DSC-HX200v no charging signal lights
profile.country.bg_BG.title
Zhelyo
According UG the power button should shine during battery charging. Unfortunatly there no light. Battery is charging, but no light showing this.
What can be the reason fot this?
2 REPLIES 2
profile.country.en_GB.title
blaireau_photo
Hello Zhelyo - Welcome to the Sony Forums :slight_smile:
If the battery is definitely charging, it may just be a fault within the light itself which might not necessarily be any cause for concern. I have had a similar problem in the past with a laptop that was plugged into a hotel socket whilst a power surge caused a power cut. After that, it has charged without any problems.
Keep an eye on the battery and if you suddenly find that the charging stops working, you may need to get it checked out.
Thanks,
Simon
Eric.D
Overheating?
HX9 UG says charging will pause until it cools enough ...
