annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
AX100 RSC 2
profile.country.FR.title
Raph-57
Explorateur
AX100 RSC 2
I would like to know if the Ronin RSC 2 gimbal is compatible with the AX100 camcorder, even though the AX100 is officially only compatible on the Ronin RS2. can it still go with the RSC2?
3 RÉPONSES 3
BlackLotus7
Bonjour Raph-57,
If you need to post here, then it has to be in French please, otherwise you have to reach the UK Sony forum 😉
And regarding your question, not sure it will be compatible 😉
Thanks & Regards,
BlackLotus7
Win_88
Spécialiste
I'm not sure the AX100 is officially compatible with any non Sony accessories. This link can be used to check compatibility directly as guaranteed by Sony: http://support.d-imaging.sony.co.jp/www/cscs/accessories/top.php?area=gb&lang=en
Raph-57
Explorateur
Thank you but.... there is no  answer for me....
