Handle accessory for FDR camera
profile.country.GR.title
ioagount
Hallo everyone,
Does enybody know if there is a handle to adapt it on shoe adaptor?
Look at the picture below to understant what I'm looking for. I do not use an external microphone and I want to find this simple handle in order to carry my camera and shoot more comfortably.
HandleHandle
5 REPLIES 5
IamNic
Hello @ioagount,
since a Hotshoe not necessarily can support the weight of a camera, I went with a handle-system, which supports itself beneath the camera while also being attached to the hotshoe via a coldshoe adapter piece (to get the connection point a few centimeters above the camera).
Here is a picture of my FDR AX100 and FDR AX700 fully rigged up:
Two FDR cameras with top handle.Two FDR cameras with top handle.
- Nic
ioagount
Hi Nic.
Thank you for your reply, but I don't think I can afford this.
I'm looking for a simple handle to hold the camera from the top and not from the side using my palm.
I want only this, so I think this would be a cheap accessory.
* I use FDR-AX33
IamNic
Hello @ioagount,
the handle system is around 100 pounds in total.
A normal grip (to mount into the shoe is around 40 pounds already, yet with the problem, that it might damage the camera: https://www.amazon.co.uk/dp/B07BK136RZ/ )
- Nic
ioagount
Hallo,
I finally found a simple Hand-held Stabilizing Grip which I was looking for.
This can lift FDR-AX33: https://www.tomtop.com/p-d6214.html
IamNic
Hello @ioagount,
good find - let me know how you like it :smile:
- Nic
