CCD-TR728E Handycam Hi8 viewfinder is blured what is wrong.
plaice
Esploratore
5 RISPOSTE 5
Pascale_F
Moderator
Hi plaice,
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Blencogo
It could be a fault but have you tried moving the Viewfinder adjustment lever?
Pull the viewfinder up as far as possible and look on the underside of the viewfinder. There is a small lever to adjust the focus for different eyesight requirements.
See Manual Page 27
https://www.sony.co.uk/electronics/support/res/manuals/3065/30656461M.pdf
If that doesn’t help a repair may be needed.
plaice
Esploratore
Hi tried the viewfinder also Zoom in and out still no joy. When you look into the viewfinder it is like looking at a negative but blured not sharp.
plaice
Esploratore
Thank you Pascale_F
plaice
Esploratore
Thanks Blencogo
