Xperia C Hang Problem
tiwarialok
My new Xperia C shuts down upon receiving call. I can hear one ring and the phone goes off. I have to restart it manually. It doesn't happen with every call but once or twice a day. I really hope Sony offers some solution.
profile.country.RO.title
_alexdon_
That could also work.Keep us updated.
alexdon
15 REPLIES 15
_alexdon_
Do you have some task killers,antivirus?
alexdon
tiwarialok
Yes.. it has an antivirus installed. Is that a problem? Should I remove it?
Tags (1)
_alexdon_
I suggest you remove any kind of apps like:antivirus,battery savers,task killers.
alexdon
tiwarialok
Thanks. Will try. Local service centre has also suggested a software upgrade. Will get it done over weekend.
_alexdon_
alexdon
tiwarialok
Gave it to local service centre. At first they took it for just software update. Then they found certain parts also needed to be changed. So it was done and phone delivered after four days. I noticed they got rid of antivirus too but did not tell me anything about not installing it again. So I don't know whether I should or not. Anyway, it has been four days and the phone is working fine.
_alexdon_
Well,at least now it is fine.
alexdon
nag1111
while i putting two sims and switching on my mobile not getting signal
_alexdon_
Set the first SIM on WCDMA and the second on GSM only.
alexdon
