Terminates Internet and mms configuration installations
Albanii
W trakcie instalacji konfiguracji sieci Internet i mms wyskakuje informacja ze nie można zainstalować tego
During the installation of the Internet and mms configuration the information pops up that you can not install this
gt
1 REPLY 1
Jonas
Master
Hi @Albanii, welcome to our forum!
Your question has been translated to English as this is an International forum.
If you aren't able to download these settings, get in touch with your operator and they should be able to provide them and if you follow the instructions below, you can add them manually in your device.
  1. From your Home screen, drag the status bar downwards.
  2. Find and tap Settings > More > Mobile networks > Access Point Names.
  3. Tap the menu button (three vertical dots), then tap the + icon.
  4. Tap Name and enter the name of the network profile that you want to create.
  5. Tap APN and enter the access point name.
  6. Enter all other information required by your network operator.
  7. When you're done, tap the menu button (three vertical dots), then tap Save.
I hope that helps! Slightly_smiling_Face
