Screen Horizontal lines
Magie
My phone is 3 months old. And it got horizontal lines on my screen. It does not fall or anything. It suddenly appears when i used it last month until now. It bothers me because the lines are continuously appearing and it becomes worst when i turn on my phone. Please help if you know what to do. Appreciate your immediate help on this.
Tags (1)
11 REPLIES 11
FrontierGate
Contributor
Screenshot please? Otherwise we won't know if it is LCD or backlight or software issue.
profile.country.US.title
Qatrium
@Magie
Try restarting your phone in safe mode and see if it persists.
You can also capture a screen shot by holding power button and choosing "Take screenshot" and post it here.
Uliwooly
@Magie
That seems like a hardware issue, you could repair the phone with PCC but you might have to contact your Local support
software repair
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
David94
https://youtu.be/DKbAPhlnyoE I have the same problem as in the video and gave repair software and still has the same problem. help me!!!
Aha15
Same Problem here, I think it was there from the beginning. Visible at the lower end of the screen, A little bit further down than the navigation bar. Exactly as in the YouTube Video posted above. It is not visible on Screenshots.
Is this a Software Problem?
Aha15
Support Askese me to Do a Software Reparieren of my phone, will See in it works
Aha15
Sorry auto correct...Will try a software repair as suggested by the Support
Aha15
Update: did not help...think I have to send it in for repair
Wa5
My xperia xA1 dropped and it got a black spot on the side of its screen and horizontal black lines.after some time the central part of the screen started continues flickring.All functions including touch is fine.no visible damage on the screen.pl help me.how can i solve this issue.
