THEPINKHOUSE-007
Wall Brackets
Can the wall bracket for the Frame 55" QLED model fit a Sony KD-55AG9 tv ?
Which model will fit closer to the wall ?
Distance for the Frame 55" TV set is 45.8mm from the wall so I would like to know if I can get the same depth with the 55" AG9.
2 REPLIES 2
Hi THEPINKHOUSE-007,
That depends on the bracket - if it is VESA conform and has a hole pinch of 30x30 cm you might be able to use it with the AG9.
Peter
THEPINKHOUSE-007
Please elaborate as I have just cancelled my order for a 55” Frame TV that would have had a 45.8mm depth and would still like to know if, when wall mounting I will achieve a similar depth if I purchase the AG9 model.
Peter
