September 2019
September 2019
using voice remote to change tv channels on Sony AG8 tv
hi, can anyone tell me if it is possible to change tv channels on using voice commands on the supplied remote. I am considering buying buying the touchpad but am not sure if this will do it if it is not possible using the supplied remote.
thanks in advance.
3 REPLIES 3
September 2019
September 2019
Hi there,
I'm looking into this and will update the thread when I have an answer.
Best wishes,
Sean
September 2019
September 2019
In italian you can ask google assistant "canale 501" or "canale Rai uno" and it swicth to the dtvb related channel. I assume in English it will be "channel xxx" or "channel BBC 1"
September 2019
September 2019
Hi Bullit509,
As far as I am aware, this model is not compatible with a touch pad remote control. What happens when you say the command to change the channel? And what command do you use?
Cheers,
The_Black_Rose
