Update error on Sony Bravia TV
B-Flores
Hi does anyone else get an error code when you try to update your TV?
B-Flores
It doesn't seems to be a problem anymore. Probably just a server error. The error doesn't show up anymore, but thanks for your reply
Sendt fra min iPhone
2 REPLIES 2
Anonymous
Hi there
Is the update error the same or similar to this thread:
https://community.sony.co.uk/t5/android-tv/sony-kdl-w755-software-an-fw-crash-error-2123/m-p/2070498
If so, please reply back with the model number of your TV.  If not, can you reply back with the exact error message.
B-Flores
