sound dropout
inessex
sound dropout
I have placed a message about this a couple of weeks ago. Whilst I have resolved part of the sound dropout problem not all. KD49x Google TV
I also note there are several references to this ( very minor) problem but I do not see a reselutution.
Playing through a Cambridge Audio there is millesecond sound dropout 2-3 times in an evenings viewing.
Sony techs do all the question about software update. Done all that. Changed cables.
1 REPLY 1
Mick_D
Moderator
Hi @inessex, welcome back :slight_smile:
Assuming your audio connection is ARC, you shouldn't have any issues. Those brief dropouts are almost certainly the TV switching connection methods, which I suspect means a bad connection at an HDMI terminal somewhere, or a dodgy cable.
I see you have changed cables but it's worth swapping them around, checking and cleaning terminals and basically ruling out a physical connection problem, before going any further.
Mick
