Sony kd49XH9505. cannot connect my iphone to airplay
profile.country.GR.title
Grifon1978
I am trying to play apple tv through my iphone 8plus to the TV, through mirroring. While the TV gives me an airplay passcode, i insert it in the iphone but doesnt work. Both devices are connected in the same WiFi
4 REPLIES 4
Hi Grifon,
Please check the following article on how to connect your phone with your TV:
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-49xh9505/artic...
Peter
Grifon1978
Thanks Peter,
I have done all those. When i mirror and input the Airplay passcode to the iphone, it doesn seem to accept it and the passcode space turns to blank again. Any idea?
Hi Grifon1987,
Unfortunately I have no idea why it isn't accepting the passcode.
Try to reboot both devices and check if this will solve the issue.
Peter
Win_88
Specialist
Hi
You can also try updating the TV: https://www.sony.co.uk/electronics/support/lcd-tvs-android-xh90xx_x90xxh_x91xxh_xh92xx-series/kd-55x...
Although I'm leaning towards the iPhone being the faulty part here as the TV does what's expected and generates a passcode.
Win_88
