Sony Bravia KDL-43WF663
garylock1963
Since a software update about a week ago, I am now unable to access YouTube, Netflix and other apps. The only to get round this is by switching my TV off at the wall, waiting a couple of minutes, plugging it back in and I can then access all internet-based stuff. I have to do this on a daily basis now which I should not have to do. On checking network settings before the reset it says:
Connection Results
Wireless Device on TV - Not Accessible
Local Access - Failed
Internet Access - Failed
All My other devices are connected to the internet Without a problem.
I went on live chat but they failed to give me a solution.
Anybody got any ideas? Is it the TV?
4 REPLIES 4
Anonymous
Hi there,
Have you tried a factory reset?
Best wishes,
M
garylock1963
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
Hi Michael,
I have done a factory reset which made no difference.
Sony gave me a firmware update on Friday which i have applied but I am still having to turn the TV on and off to get onto Netflix etc.
Says Check Connection and not connected to the Internet.
I had no problems until a software update over 2 weeks ago.
Gary
rooobb
@garylock1963  ha scritto:
Connection Results
If it says that no wireless device is found there is nothing related to firmware, unless you disabled WIFI on your tv..
BTW your tv is not an android one, so this is the wrong section of the community
garylock1963
I realised that my TV is a smart TV not an android and I have posted it in the wrong section.
