Sony Bravia KDL-43W755C
Hi everyone. As in subject i have Sony Bravia KDL-43W755C since couple of weeks and i have a little problem. When im trying to change anything in screen setup or sound setup from main TV settings i cant do notjing. It shows "DirectSettings app has been stopped". Any solution exclude "Factory Settings"??
Tags (1)
1 REPLY 1
Anonymous
Hi there
Try rebooting the TV.  Press and hold the power button on the remote control for 6-10 seconds and the tv should then restart.
Im assuming you have the latest FW installed?
All else 'factory reset'
