Sony Bravia error message with Freeview Play connection
Hi
I don't use Freeview on my Bravia as it's only connected to my WiFi network. Now for some reason I'm trying to access BBC iPlayer and other UK channels and I'm getting an error with Freeview Player at the top of the dialog. The error shows "Oops connection error - code: FVP-03-023".
I don't want to connect to Freeview so I disabled the app.
Still getting this error. Given up now as I need to do some work.
Am I alone with this situation?
Would you please let us have the full model number of your TV, it will start with KD or XR.
To use the iPlayers you probably need YouView or Live TV & Catch Up (depending on your model number) enabled. There is no need to use these Apps, just have them enabled.
Hi
Your helpful support staff member walked me through the process patiently. In the end I had to revert to factory settings. All was well after that.
I have the same problem with Error fvp-03-023. My Sony model KD32-W800.
Hey @Zennaman
Have you tried unplugging your TV from the mains for at least 2 minutes and testing it again without any external devices connected?
Did you check also if other apps can access the internet?
All remedied after an 'unplug'. Thank you.
