Sony AF8 TV turns off
theflyingdove
Hi, is it normal that sometime changing between apps the TV turns off? It only happened once when exit the video app to live TV and I press it back to the tv button and the back button very fast and it was when turns off . It has happened to me once in a week that I have it ...
Thank you.
1 REPLY 1
Pascale_F
Moderator
Hi theflyingdove,
Welcome to the community.
It might be worth doing a reset or factory data reset on your AF8. You can find instructions here.
Thanks,
Pascale
