karlreg
Sky Q and XG9505
i have only just got my TV today and all is a bit mental to get everything setup. Is it possible to use my Sony remote to control my Sky Q box (key in channel numbers, view favourites etc)
If so...how do I do it?!
3 REPLIES 3
quartz-909
You won’t be able to use the Sony remote in the same way as you do your SkyQ remote, but turning on ARC control on in the TV settings for HDMI can give you some control over the SkyQ box, even tho it’s a little limited.
quartz-909
Joe_Dohn
Specialist
The setting needs to be enabled in the TV under "Bravia Sync Control" and in the SkyQ box under CEC or HDMI/ARC control or something similar to that.
