Remote Control Mapping
ctrlzuk
I have a Sony KD65X8509C TV, based on Android TV and which comes with a RMT-TX100D remote control.
Is it possible to re-map buttons on the remote control?  For example if I wanted to disable a certain button or make the Netflix button launch a different application?
As it's based on Android TV I thought maybe the remote mapping may be accessible in a config file or something...
1 REPLY 1
Anonymous
Hi there
No, unfortunately you cannot do this.  Its not a programmable remote.
