remote control for KD-43XD8099
daveP_uk
Hello,
I need to replace my TV remote control, I'm in the UK.
What is a reasonable price for a remote control.
Or any suggestions on where to buy, other than standard Amazon.
TIA
LightFoot
Specialist
Hi @daveP_uk
You can expect to pay up to £70 for a genuine Sony RMT-TX200E.
SONY RMF-TX200E Remote Control Original (remotes4u.co.uk)
What have you got against Amazon or a genuine counterfeit on Ebay?
5 REPLIES 5
LightFoot
Specialist
Hi @daveP_uk
daveP_uk
Thanks
Generally Amazon can be overpriced
Ebay = a lottery
SkyNet404
Specialist
You can try a company called ''Your IT delivered'' as well: https://www.youritdelivered.com/
daveyh64
Enthusiast
royabrown2
Hero
Very odd, and a bit of a mess there. It says the much cheaper one is an EU model, and may be different from a UK one.
Or you can follow the link to the Sony Store:-
https://www.amazon.co.uk/stores/page/23FAF1CB-76C7-4F35-BB1D-3EB07771A7D2/search?ref_=ast_bln&terms=...
where the £28 one is described as TX200 (no E) and the one with the E is £75, UK-supplied, but by a third party.
But the Quick Look at the £28 one then says it is a TX200E.
Or outside the Sony Store, there’s a knock-off for £7, that may not be a TX200E but is claimed to be compatible, or a One For All at £17, which does not pretend to be a TX200E but likewise claims to be compatible.
Choices,, choices…..
