Is this TV bluetooth enabled? I have tried researching online but can't find whether it has bluetooth capabilities or not..
It does have a bluetooth interface... but probably not for what you are looking for. AFAIK you can connet only a BT mouse on non-android Sony TVs
Thanks for your reply Rob
So does this mean I won't be able to use wireless headphones with it? I'm new to all this, haven't upgraded my TV in years, things have changed so much!
Hi there
I have had a hunt around, and I also cannot find any mention of Bluetooth. Previous years models you could connect a mouse for use on the TVs inbuilt web browser.
However, to use Sony's one-flick remote, this connects to the TV via bluetooth - so it does have it, but in a very limited capacity. Unfortunately as roooobb mentioned above, you will not be able to connect bluetooth headphones to the tv. This is because there are various different 'profiles' of bluetooth - each one doing a different function.
