KDL - 43W809C
Hi Please can someone help me, I am loosing the will to live!
My TV keeps turning itself off, its like it is rebooting, when it finally turnes on it tells me that "unfotuntley gamepadmanager has stopped" and "anriod.score" and "Unfortuntely your FreeView has stopped" none of the buttons work, nothing works! I have turned off by the mains, by the swtich on the tv. I have even tried to do some sort of usb download but nothing is working. This is ridiculous.
Is there anyone that can help me please!!
I'm not familiar with this model but my first thoughts would be to try a 'soft' reset, typically done by holding the power button on the remote for up to 10 seconds until the TV reboots. If that fails then disconnect all external connections apart from aerial and try again. If still no good then try a 'factory reset' which should be detailed in the user manual.
Good luck.
