juliehobbs
KDL-32WD751
Hi could you tell me is there an update to be able to access itv and channel 4 on the KDL-32WD751?
Many thanks
Anonymous
Hi there
If the BT Box is the BT YouView box, then yes those catchup players are available:
http://bt.custhelp.com/app/answers/detail/a_id/40469/~/youview-from-bt-and-how-to-get-it
However I would confirm with BT before doing anything.
5 REPLIES 5
Anonymous
Hi there
Unfortunately ITV Player and 4OD are catchup apps that are not supported on your TV.  Only Android TV with YouView enabled will have access to those two catchup streaming apps.
juliehobbs
Thank you, would a bt vision box give me the apps?
Anonymous
Hi there
juliehobbs
Brilliant thank you it is the you view box as I am with BT.
Anonymous
You're Welcome :grin:
