KD-55X8509C PS4 Pro HDR washed out look
The_Notorious
Hi all,
Has there been a resolve yet for the washed out look while HDR gaming yet? I really want to make use of this feature?
i have the latest firmware on the TV also.
Also are all 4 HDMI ports 4K HDR compatiable.
thanks
3 REPLIES 3
cass_n
Hi @The_Notorious,
Can you share some more info on the washed out look while HDR gaming please?  And if possible a photo?
Re the HDMI ports - yes they should all be 4K HDR compatible.  Just make sure you've set them to Enhanced Format (see instructions here).
Cheers,
Cass
The_Notorious
Hi @cass_n
Thank you for your reply. I have enhanced on as I am getting 4k when gaming.
As for the washe dout look, for example Battlefield 1 when i play the screen looks like it has a grey mist over it.
when I turn HDr off it goes away and looks really crisp and clear. On HDr the details does appear better but just the colour seems really off even though i have tried to adjust and as mentioned it looks like a grey mist if over the screen.
cass_n
Thanks for the additional details.  Are you able to share a photo?
