ITV Region Wrong
Prior20
ITV Region Wrong
HI All
so ive had 2 55" sony TV's 755 & 805, both have dispayed the ITV HD channel as west region when im infact in the east region,  The standard def channel displays the east region as it should.
Any ideas
jumpsuit
Hi :slight_smile:
Do you know if your local channel has HD broadcasting capability?
If your standard channel is showing the right region then it could be because your
region doesn't have local HD broadcasting capability,
3 REPLIES 3
jumpsuit
Hi :slight_smile:
Prior20
jumpsuit
:slight_frown:
Its a bit of a pain having to switch over to standard,
but at least the hd is on their list of 'things to do' :slight_smile:
