Illumination led won't switch off
hungledink
I have a xd8088 tv.
I  have the illumination led set to only show when the remote is being used. Although I have that as the setting, the led is staying on all the time, even if there is no remote being used.
I can can switch it off completely but don't want to do that.
Anyone know now how to fix this?
2 REPLIES 2
Anonymous
Hi there
On some TVs you can customise the illumination LED - but Sony seems to have added a caveat in the online instruction manual:
http://helpguide.sony.net/tv/daep1/v1/en/07-01_01.html
[Illumination LED]
Customises the Illumination LED.
(The availability of this function depends on your model.)
Check the settings again and see - but if not, you might be out of luck on this one.
hungledink
I did a full power down and then back on and its sorted itself out.
Thanks anyway.
