How to stop HDMI Information Banner on KD-49XG9005 using Android 9 latest firmware???
warlord01
I wish to stop the information banner from being displayed at random times whilst watching TV etc on my XG9005.
After searching around, I found out that prior to this latest update (v6.7140) that you could enter the menu:
Home > Settings > Channel Setup > Info Banner > OFF  and disable the notification.
There must be a way to achieve this under the latest firmware, as it is spoiling my viewing experience and is becoming a major annoyance!!
Any suggestions gratefully received 😀
53 REPLIES 53
warlord01
Yes, used USB update - now completed on two sets with no problems 👍🏻👍🏻
CosmicCat
Great news!
Do you know if the underlying problem is fixed or have you just turned the banners off?
Either way I look forward to being finally rid of them.
It's been a long wait but thank you Sony at last.
jonH68
At long last it seems the latest firmware has resolved the banner situation.
Because of the issue I connected the Virgin 360 box and Apple TV4K directly to the TV with a pair of stereo Homepods replacing my previous L-C-R speaker set up so the Denon AVR appears redundant now.
bajones01
Yes this really irritating fault appears to finally have a solution - the ability once more to turn off the display banner in the software may be a workaround but a very welcome one at that!
