Freeview on model KD-55XH9505
Merdugneo2
I bought my Sony TV model no  KD-55XH9505, on the assumption that it had freeview included, but I can't find it anywhere.
Going through the Sony support page is about as easy as navigating a maze
I'm not very tech savvy , so any help is gratefully appreciated.
4 REPLIES 4
LightFoot
Specialist
Hi @Merdugneo2
If you disable YouView you will get Freeview. You cannot have both.
I don't have your particular software running on my TVs so as a general guide:
Home -> Settings -> Watching TV -> Channels -> Channel setup -> YouView setup -> Disable YouView.
Note by disabling YouView you may disable some of the iPlayer Apps.
Merdugneo2
SRory I never got back to ou, but I gave up in the end.
However I tried again last month and finally managed to di it without having to disable You view, so win win!
Sorry it's Ben so long in coming but thanks for the input .
Merdugneo2
Sorry even 🤣
Merdugneo2
Sorry for the spelling, predictive text is a  bit of nightmare 😡
