PaulinBont
eARC port location?
Hello,
I need to plug a HDMI cable into the eARC port on my AF9 but as the tv is wall-mounted I have to try and do it by feel as I can’t see which port is which due to very limited clearance above a mantel beam. Does anybody have a photo showing which of the HDMI ports is the eARC enabled one please?
Thanks,
Paul
Joe_Dohn
Specialist
The Manual has a helpful illustration on page 11.
2 REPLIES 2
Joe_Dohn
Specialist
PaulinBont
Thanks Joe.
  • According to Richer Sounds, the 2018 AF9 is eArc enabled but doesn’t have an eArc port like the later models: AG9, AH9 etc. Enabling eArc is carried out by doing the software update, using the ‘Arc’ port
