disable digital antenna input - 43XD8305
how do i disable the digital antenna input?
i had previously connected an antenna to test youview (not knowing that it took over the TV and forced the TV button on the remote to only control Youview).
i diabled youview and disconnected the antenna, but digital input won't disappear and the saved channels are still there.
reason i want it removed as when the TV comes on out of standy, it default to digital input even though the TV button on the remote is set to HDMI1.
also. any way to get rid of the streaming channels input?
it only has google play movies attached to it.
i know you can hide the inputs, but that doesn't seem to be the same as actually disabling them.
it would appear to be all HDMI CEC functions, so yes, numeric buttons, GUIDE, PROG +/-.
this is after waking up from standby, the TV is never physically powered off.
Did you also try Factory Reset your Sat receiver?
Check also Sync settings of Sat receiver, if existing of course.
Seems like a compatibility issue.
It's a Sony TV issue, box does not have the same issues when connected to a Samsung TV.
The don't y TV is clearly not enabling HDMI CRC immediately for some reason
- « Previous
- 1
- 2
- Next »
