Can't connect screen mirroring or wifi direct with my phone sony kd 55a85 tv
Paulis
Bought last year (2022) sony kd 55a85 tv and want it now connect samsung dex wirelessly through phone just find it impossible try to look options and find out that sony don't have screen mirroring on tv's after 2020.... my head already overheated can't find way..
Please can any one recommend any possible way to connect phone with tv..?
Thanks
11 REPLIES 11
Alirasouli
I am also using a Sony KD-55X85J TV and unfortunately it does not have the screen mirroring option at all and it seems to be a software problem because once I installed a program that caused a software shock and I found the screen mirroring option in the inactive programs section. Unfortunately, there was no option to activate it, and I had to do a factory reset, after which I couldn't find it at all.
If your problem is solved, please send your solution to this email address
Edit - Email address removed for your security on a public forum.
royabrown2
Hero
@Paulis
Dex is Samsung proprietary. It only works with Samsung TVs.
