Built in tuner not recognised
Sparqui
Hi everyone
Im new here (great forum) and would like to ask for some expert help - I’ve reached a dead end.
I have a KDL-55W805C, upgraded to Android Nougat - I no longer have the tv tuner capability.
It doesn’t offer it as part of the initial set up, nor as an input, not under TV menu (no channel set up menu)
ive done a hard reset, reinstalled the firmware (by usb), cleared storage - no joy.
Any help would be great (fingers crossed)
Thanks
Tags (1)
11 REPLIES 11
royabrown
Enthusiast
The TV tuner capability, by default or after a hard reset, is provided by YouView.
Can you see, and choose, that option on your menus?
YouView Superuser, but not an employee of YouView, nor retained by them for this purpose. It's purely me speaking
Sparqui
Hi there - thanks for taking an interest.
Sadly I have no menu option, under the tv menu(from the home screen), it lists streaming services- then the HDMI and av connections
Nothing for channel set up, Youview or any other.
A bit flummoxed!
Sent from my iPhone
royabrown
Enthusiast
As well you might be.
If it is still under warranty, I would suggest talking to the retailer you bought it from, who can either sort it for you, or swap the TV if it is faulty.
But can you post a screenshot here, so we can see what you see when you put the TV on?
Sparqui
Thanks again for this.
i have made a support request to Sony to see what can done - fingers crossed .
To give you the screenshot they should be available in this message
Many thanks
Sparqui
Apologies, I have to wait 24hrs before I can upload
ill post them tomorrow
Sparqui
Hi Royabrown
Apologies for the delay - here are the imagesHome screenHome screen
Settings->TvSettings->Tv
Channel guideChannel guide
Sparqui
But - they are upside down!!!
royabrown
Enthusiast
Can you not scroll up above that Apps line?
Sparqui
Ny apologies- does this help?
Below appsBelow apps
External souresExternal soures
