Bravia Xbr-65a8g built-in wifi wont stay on
foo123
Android updated something last week, had to turn built-in wifi back on afterwards. Worked fine thru yesterday. Turned set on this morning and built-in wifi wont stay switched on.
Have power cycled both TV and router multiple times
Android v8.0.0 kernel 3.10.79
I can't see anything with a recent date but it was definitely an Android update last week
Any advice most welcome
foo123
That's kind of you. I would like to stay on here then, thanks 🙂
Yes a factory reset fixed it. Thanks for that suggestion. My TV is pretty useless without an Internet connection. Living in a tight mountain valley, even an over the air antenna can't pick up a signal
Thanks to all
7 REPLIES 7
LightFoot
Specialist
Hi @foo123   I am surprised that your American model TV works in Europe. I thought that they had a different digital terrestrial tuning system (I am probably wrong). If you haven’t tried it, I would try a factory reset. As you probably know, your TV will not be supported in Europe.
foo123
No my TV and I are in the US. Does that matter for this forum? It's the only forum that came up in Google search
foo123
So I will remove myself from this community and look for an American one. Thanks!
LightFoot
Specialist
Hi @foo123
I did reply almost immediately yesterday, with a link to the US community. I see it has disappeared, probably eaten up by the spam filter, as it was purely the link below.
Official Sony Electronics Community
LightFoot
Specialist
Hi @foo123   I tried to send you the link to the US community yesterday and just now but it gets deleted by the spam filter. 😂
jumpsuit
Hi @foo123  and welcome to the UK community :slight_smile:
No need to leave this forum if you join the USA one, stay with us and then you'll have
the best of both worlds 😉
Did you manage to factory restore your TV?
foo123
Thanks to all
