Dary_kk
Bravia cam
Hi there. I have sony google tv xr55x90ku without built in mic. Would I be able to use google assistant hands free if I add bravia cam to my tv?
2 REPLIES 2
LightFoot
Specialist
Hi @Dary_kk
I cannot see "voice commands" or "google assistant" in the blurb. My guess is you can only use the Mic on your remote.
Everything you need to know about BRAVIA CAM | Sony UK
Anonymous
Yes, it won't support hands free search as well even with Bravia cam. You can use the remote mic at this point.
Even though the camera got a built in mic, you can only use it for video chatting not hands free searching.
