Best PS4 Pro Settings for KD-43XG7073
GoodSonyBoy
Hi PS4 Pro players. What's the best settings for a Sony Bravia TV? I'm fiddling around trying to customise the Game setting but I'm getting nowhere. Any ideas? Thanks SonyBoy 🙂
2 REPLIES 2
Try setting the TV to default settings, then using BraviaSync to connect to your PS4 Pro via the HDMI 3 ARC (Audio Return Channel) port.  This will allow you to select the highlighted, recommended options within the PS4 Pro menu on the PS4 Pro itself.  This also allows you to use your TV remote control to control the PS4 Pro.
GoodSonyBoy
Thanks BlueBadger 🙂
